2001 Honda Civic Cold start rpm surge when going uphill
2001 HONDA CIVIC
127,000 MILES • 4 CYL • FWD • AUTOMATIC
JALEWIS
Lately, I've noticed the rpms surge between 3000-4000 while going 60-70 mph. This seems to only happen when going up an incline and only after a cold start. This either goes away after a few minutes or after restarting the engine. Then it drives fine the rest of the day. This doesn't happen if the road is flat. I had the transmission flushed at 123k, and nothing was found out of the ordinary. No codes present however last week the engine light came on and the engine stalled. I had the codes checked and it read P1361-intermittent interruption in the TDC sensor. I reset the PCM per the Honda service manual and checked for codes: no codes present. The manual says that its fine, for now. Any ideas?
Aug 10, 2009 at 12:28 PM
F4I_GUY
  • 3,302 POSTS
One of the sensors in the distributor might be failing (that is where you get your RPM signal from).
If that code re-appears, you'll have to replace the distributor.
Aug 10, 2009 at 5:55 PM
