2000 Honda Civic SLOW ACCLERATION
2000 HONDA CIVIC
BULLOCK456
Drive Train Axles Bearings problem
2000 Honda Civic 4 cyl All Wheel Drive Automatic
HOW COME MY HONDA HAS SLOW ACCLERATION
Jul 31, 2009 at 8:28 PM
When was the last tune-up? Could be caused by the following:
Oxygen sensor
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Jul 31, 2009 at 8:53 PM
