it is very possible it is the bearings !
WHEEL BEARING
Inspection
Wheel bearings are not adjustable. Bearings should be checked for excessive movement. Support vehicle, and remove wheel.
Install dial indicator with stem positioned on front hub surface. Move hub assembly in and out. Note reading. Movement should be 0-.002" (0-.05 mm). If movement is not as specified, replace bearing.
Dec 11, 2020 at 1:03 PM
(Merged)
