2000 Honda Civic my 2000 civic has a iac and knock sensor p
2000 HONDA CIVIC
155,000 MILES • 4 CYL • FWD • AUTOMATIC
BDBY1977
ok to start off i put a new knock sensor in it and tried three diff throttle bodies with the iac i can clear the codes drive about ten min and lights back on same codes any other suggestions please other than dealer. there is no vac leaks i had a smoke test done i have a solus diagnostics mechine thanks jason
Jun 9, 2010 at 9:21 PM
KHLOW2008
  • 41,814 POSTS
Hi Jason,
Thank you for the donation.
Since the code is recurring, it could be a fault with the wiring or PCM and we would have to go into diagnostics.
What are the EXACT trouble codes?
Jun 10, 2010 at 8:08 AM
BDBY1977
[quote:078b8c26fa="KHLow2008"]Hi Jason,
What are the EXACT trouble codes?[/quote:078b8c26fa]
first code is p0505 iac second code is p0325 knock sensor. thanks jason
Jun 10, 2010 at 5:33 PM
KHLOW2008
  • 41,814 POSTS
I have emailed the diagnostic files to you, hope they are helpful.
Jun 11, 2010 at 8:48 AM
