2000 Honda Civic Car Squeels while driving
2000 HONDA CIVIC
68,000 MILES • 4 CYL • 2WD • MANUAL
VADKA
  • 9 POSTS
Hi there, my car starts making this squeeling noise kind of like a lose belt only when i drive. Well it actually starts squeeling after i drove on the freeway (at speeds of 70-80 mph) for about 10-15 minutes. After that it starts squeeling and doesnt stop until my car is cooled down. I noticed when my car is cold or even if the engine is runnuing at normal operating temperature not for a long time, then there is no squeeling, but after it ran for a while at slow speeds, or bout 10 minutes at high speeds, it starts squeeling. Oh and another thing is, idk if this has anything to do with it, but i have a guage that shows air/fuel ratio and when the car is cold the needle jumps around in the optimal area. When the car gets warm or normal teperature, the needle jumps all the way from rich to lean so it jumps from the bottom to the top. Could that have anything to do with it? If not, why does it do that? Oh and my car is running rich right now as well. Thank you for all your help, sorry the ? is so long
Oct 20, 2008 at 7:27 AM
KHLOW2008
  • 41,814 POSTS
Hi Vadka,
The noise could be from the radiator or condenser cooling fan motor.
Nov 3, 2008 at 8:23 AM
VADKA
  • 9 POSTS
Oh ok thank you, but how could it be the radiator? why would the radiator make that sound and only when the engine gets hot? anyways, if its either of those two things that you said, I should just replace them right?
Nov 4, 2008 at 9:57 AM
KHLOW2008
  • 41,814 POSTS
Hi Vadka,
Not the radiator, what I meant are the cooling fan motors.
If they are noisy, it means they are failing and should be replaced.
Nov 4, 2008 at 10:42 AM
VADKA
  • 9 POSTS
oh ok ic. well i did this one test when i was driving and my car was making the squeeking noise, i turn off the car all the way and let it roll in nuetral, so all the fans were of and the engine was off but it still was squeeking. any ideas?
Nov 4, 2008 at 10:44 AM
KHLOW2008
  • 41,814 POSTS
Hi Vadka,
In that case, it should not be from the engine. Most probable cause would be from the wheel bearing rear seals brushing against the CV joints.
Nov 4, 2008 at 10:57 AM
