firing order?
2000 HONDA CIVIC
11,000 MILES • 4 CYL • 2WD • AUTOMATIC
HOBREGON
Honda 2000 Civil LX - rebuilt by someone after being totalled. Distributor was replaced back in May, ran fine for a month, then started missing and firiing oddly then just died. Started up was able to run but it ran rough and shaky.
Where we are now, spark plug cables have been replaced, need firing order to check and see if is correct. Also, the intake tube is MISSING, don't know who took off but an auto parts employee said that is okay - what is it called and do we need it, would the car run better if it were on?
Oct 21, 2009 at 2:19 PM
DOCFIXIT
  • 18,828 POSTS
Here is firing order
https://www.2carpros.com/forum/automotive_pictures/198357_Graphic_194.jpg
Jun 1, 2020 at 11:37 AM
HONDA.FREAK818
what is the firing order?
Jan 4, 2021 at 1:57 PM (Merged)
JDL
  • 16,098 POSTS
My info showed this for a civic cx. 1342 is the firing order.
https://www.2carpros.com/forum/automotive_pictures/170934_civic_firing_order_1.jpg
SRBSTN2256
  • 62 POSTS
need diagram for plug wires on dist keep getting firing order diagrams but not clear enough to understand them with cap on car need diagram for distributor on car and maybe i can get it back wired up.
KHLOW2008
  • 41,814 POSTS
Here is the engine spark plug firing order. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Cheers
DCASH0995
Im trying to find the proper order to install a new set of spark plug wires
2CARPRO JACK
  • 11,533 POSTS
Hope this helps
https://www.2carpros.com/forum/automotive_pictures/1639_honda_firing_order_1.jpg
RMARCHELL
My wife purchased new spark plug wires and plugs. She took off all of the plugs from the distributor cap and I don'y know which order to put them back on. Do you know which wire goes to which plug? If not, would it hurt the engine if the car was started and the plug wires were not connected correctly to the distributor cap? If the car can be started without causing damage, how can I tell if the wires are on the correct distributor terminal?
ZACKMAN
  • 4,202 POSTS
https://www.2carpros.com/forum/automotive_pictures/55316_CivicLX_1.jpg
Your cap should look like the bottom right.
L2WO4OUR
  • 20 POSTS
What is the firing order on a d16y8. car will not start. What about in the engine? Which is cylinder number one? And when checking the timing the number one cylinder is top dead center which way should the distributor rotor be pointed?
KHLOW2008
  • 41,814 POSTS
1 - 3 - 4 - 2 clockwise looking from top of distributor. Check the diagrams out two posts down Distributor is at cylinder number four.
Refer to diagram below!
L2WO4OUR
  • 20 POSTS
Thanks that did the trick I love this site
DEMIREW ASFAW
what is the firing order of honda civic dx 1.5 engine
ZACKMAN
  • 4,202 POSTS
https://www.2carpros.com/forum/automotive_pictures/55316_95civicfiring_1.jpg
JULIE HORTON
Please help! need the correct firing order . My friend took the distributor cap off with out writing down firing order,... thanks
Jan 4, 2021 at 1:58 PM (Merged)
KHLOW2008
  • 41,814 POSTS
Hi julie horton,
1 3 4 2 clockwise on cap side.
HCALDERON
1989 Honda Civic 4 cyl Front Wheel Drive Manual
I want to know the firing order for a 89 dx civic 1.5L
MERLIN2021
  • 17,250 POSTS
https://www.2carpros.com/forum/automotive_pictures/62217_Hond_CIVDX_1.jpg
1-3-4-2
