1999 Honda Civic uses oil
1999 HONDA CIVIC
93,000 MILES • 4 CYL • 2WD • AUTOMATIC
KOSMUNDSON
Between oil changes the car uses 1-1.5 qts of oil. It is not leaking. Could this be leading to a serious problem?
Sep 30, 2010 at 6:43 PM
SATURNTECH9
  • 30,869 POSTS
How many mile's in between oil change's?
Sep 30, 2010 at 6:59 PM
KOSMUNDSON
right around 3,000 miles.
Oct 1, 2010 at 2:57 PM
SATURNTECH9
  • 30,869 POSTS
That's not that bad i think honda allows 1qt per 2,000 mile's of oil usage if memory serve's right.Your vechile is just using some oil i would check the pcv see if that is sticking open that could add to oil usage.Using some oil could damage your cat and o2 sensor's but that's what happens when engine's start using oil.You could get some lucas oil stabilzer that will help slow down oil usage.Aside from doing a rebuild or a engine replacement you don't have many choice's.
Oct 1, 2010 at 7:12 PM
