Got a 99 civic with this problem: Car starts, transmission shifts but car won't move...
Clutch pedal travels all the way, there are no noises when engaging/disengaging the clutch or starting the engine, don't see any oil leaks anywhere nears the trans or on the axles going into it. Everything seems to be fine except when I shift to any gear the car does not move. Just stays there as if in neutral...
Yes, the brake is not on, if it were and the trans engaged the car would stall!!
Oct 27, 2010 at 9:03 AM
