1999 Honda Civic high compression pistons with turbo
1999 HONDA CIVIC
STARSY
Engine problem
1999 Honda Civic Front Wheel Drive Manual 106 miles
recently bought high comp pistons/rings for my b16a2 with t4 turbo the comp ratio is very high its 12:1 with a low boost 3-5psi can u tell me what problems i might encounter any info on this matter would be greatly appreciated.
Dec 2, 2007 at 1:22 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
I would be worried about the ECU parameters to operate efficiently. Next would be the crank shaft, you are going to ask it a lot. Turbo cranks are heavier. All other engine components are going to be working over time as well , the harder you push it, the closer you are to something failing. Cooling systems may not cope as well in warmer temp's not to mention transmissions and drive shafts.
have a good hard thing about doing only 1'2 a job, reliability high performance does not come cheap.
Mark (mhpautos)
Dec 3, 2007 at 2:34 AM
