1999 Honda Civic Crankshaft pulley
1999 HONDA CIVIC
195,000 MILES • 4 CYL • FWD • AUTOMATIC
SHEROD25
My crankshaft pulley is shaking while ist rotating. It knocked my ac belt off track. How can I fix my crankshaft pulley?
Oct 12, 2008 at 6:42 PM
Make sure the crankshaft key is in place and then torque to its specifications
Oct 12, 2008 at 6:51 PM
BRUCE HUNT
  • 3,754 POSTS
Check to make sure the balancer or pulley is NOT worn. If any wear is seen replace it. You can buy them used online. $15 or $20 bucks. As Raz said make sure the key is there and then also check the crankshaft end for any damage. Install the new balancer and tighten. There is a special tool to help get the bolt tightened properly. It is very important that the bolt is tightened to specs. Very important because you do not want that to come loose again.
Oct 13, 2008 at 11:58 AM
