1998 Honda Civic WINDSHEILD WIPERS
1998 HONDA CIVIC
122,000 MILES • 4 CYL • FWD • MANUAL
RVARGAS64
HELLO
LAST WEEK DURING A RAIN
TURNED ON WIPERS , WORKED FINE
TURN SWITCH TO OFF POSITION,
BUT STAYED ON!!
SLOW /FAST WORK FINE, INTERMITTIN NOT WORKING.. ONLY WAY TO TURN OFF , WAS BY REMOVING FUSE .. PICKED UP A SWITCH AT JUNKYARD. THE WHOLE ASSEMBLY..
SAME THING WILL NOT TURN OFF..
HELP!!
Aug 27, 2008 at 3:29 PM
KHLOW2008
  • 41,814 POSTS
Hi RVARGAS64,
Check the intergrated control unit attached to rear of underdash fuse box.
Aug 29, 2008 at 2:49 PM
RVARGAS64
BUT STAYED ON!!
HELP!!
YOUR REPLY, WAS CHECK INTERGRATED CONTROL MODULE, BEHIND FUSE BOX...
TRIED THAT WITH WORKING UNIT, STILL WILL NOT TURN OFF... THANKS
Sep 9, 2008 at 1:27 PM
KHLOW2008
  • 41,814 POSTS
Hi RVARGAS64,
Did some research and came out with a TSB for this problem.
WINDSHIELD WIPERS DO NOT PARK OR SHUT OFF TECHNICAL SERVICE BULLETIN
Reference Number(s): 00-031, Date of Issue:  May 16, 2000
HONDA: 1998-2000 Civic
CATEGORY: Body Electrical APPLIES TO: 1998-1999 Civic - All 2-door models; 2000 Civic - 2-door models from VIN 1HGEJ....YL000001 thru 1HGEJ....YL043357
Related Ref Number(s): 00-031
ARTICLE BEGINNING SYMPTOM
The windshield wipers do not park or shut off when you turn the windshield wiper/washer switch OFF.
PROBABLE CAUSE Broken park position reed switch.
CORRECTIVE ACTION Replace the windshield wiper motor.
PARTS INFORMATION Windshield Wiper Motor: P/N 76574-S01-A07, H/C 6094296
WARRANTY CLAIM INFORMATION In warranty: The normal warranty applies.
Operation number: 740100
Flat rate time: 0.6 hour
Failed part: P/N 76574-S01-A06, H/C 5194139
Defect code: 072 Contention code: B03
Template ID: 00-031A
Skill level: Repair Technician
Out of warranty: Any repair performed after warranty expiration may be eligible for goodwill consideration by the District Service Manager or your Zone Office. You must request consideration, and get a decision, before starting work.
http://www.ondemand5.com/mric/common/asp/printart.aspx
Sep 10, 2008 at 2:04 PM
