1998 Honda Civic Piston Rings
1998 HONDA CIVIC
148,000 MILES • 4 CYL • FWD • AUTOMATIC
C_OSORIO
What size rings do I need to buy for this vehicle after honing the cylinders, also is it posible to replace the rings without removing the head.
Thank You!
Jun 22, 2010 at 4:27 PM
If your cylinders is within the normal wear use the OEM part as for you taking out the head you have to best have a ridge reamer/ring compressor when you decide to do it
Jun 22, 2010 at 4:37 PM
C_OSORIO
[quote:3d9f758fe1="rasmataz"]If your cylinders is within the normal wear use the OEM part as for you taking out the head you have to best have a ridge reamer/ring compressor when you decide to do it[/quote:3d9f758fe1]
How do I know If the cylinders is within the normal wear use
Jun 22, 2010 at 4:58 PM
You need a telescopic gauge and a micrometer to do it-check the auto parts store there's many special tools involving engine rebuilding it has to be done right
Jun 22, 2010 at 5:01 PM
