Electrical problem
1998 Honda Civic 4 cyl Front Wheel Drive Automatic
When I use the turn signal they work fine until I depress the brake pedal then the turn signal goes out. When I release the brake pedal the turn signal resumes. With the car is parked and the key removed, depressing the brake pedal causes the buzzing sound that is made as if the key is left in the ignition. I think the brake pedal switch may be bad and causing an electrical shortage. Could that be the issue?
Aug 28, 2008 at 7:50 PM
