1997 Honda Civic o2 censor
1997 HONDA CIVIC
14,500 MILES • 4 CYL • FWD • MANUAL
SICWITHHATE
  • 7 POSTS
1997 honda civic check engine light came on, scanned it, came up that it was the second censor, so i replaced the censor, when i got the codes erased the check engine light came on within three seconds of the car being started..
Feb 10, 2009 at 4:08 PM
F4I_GUY
  • 3,302 POSTS
What exactly is the code?
You may have an open or shorted wire in the circuit, did you check the wiring going to the sensor?
Feb 10, 2009 at 5:43 PM
SICWITHHATE
  • 7 POSTS
heater sensor 1/2 is the code...i talked to a few people and they said it may be a bad cat converter...i have no clue...my inspection is way past due and i live in new york so they are kind of strict
Feb 10, 2009 at 6:45 PM
ZACKMAN
  • 4,202 POSTS
What my colleague asked for is the ACTUAL CODE NUMBER, not just description. But, if I understand your description correctly, you said Heater Sensor Bank 1 Sensor 2. And you were told it was the cat converter.
Those people are wrong. It has something to do with your rear O2 sensor harness going back to the ECM. Your O2 sensor grounds at the ECM, and that circuit is bad. So, go under the car and make sure that the harness is connected tight, and follow the wires as much as you can to make sure that it is not cut, frayed, etc.
But we still need the actual code numbers to be accurately sure.
Feb 11, 2009 at 2:42 AM
F4I_GUY
  • 3,302 POSTS
Like Zackman said. It sounds like you were told it was Bank 1 Sensor 2, which is your post-catalytic oxygen sensor.
However, we need the code number to help you determine what is going.
If it is the heater code for your secondary o2 we can post up how to test the wiring for the heater circuit if you indeed did replace the proper o2.
Feb 11, 2009 at 5:41 PM
SICWITHHATE
  • 7 POSTS
the guy that ran the codes on my car lives about 30 miles away and is not able to test my car, he also ran a test on another car so the my codes were not stored...best he could give me was p0...sorry....i talked to a mechanic i work with and he said it may be the wiring as well so im getting a voltage tester to test the wiring harness any suggestions on which wires to test?..and if it is a wiring problem how much of a pain will it be to locate the bad wire?
Feb 11, 2009 at 8:24 PM
ZACKMAN
  • 4,202 POSTS
https://www.2carpros.com/forum/automotive_pictures/55316_97civicb1s2_1.jpg
https://www.2carpros.com/forum/automotive_pictures/55316_97civich02s_1.jpg
https://www.2carpros.com/forum/automotive_pictures/55316_97civicecm_1.jpg
Check continuity on all highlighted circuits. Repair any open circuit. If all circuits are good, replace the O2 sensor. It can be a major PITA to find bad wire. Just imagine you have to connect one end at the O2 sensor connector (under the car) and the other probe in the kick panel. Once you know the bad circuit to repair, ten you have to literally trace the wires. But it can be fun-filled, knowledge-seeking adventure. Do you have an Autozone close by? They can can scan your ECM for free..
Feb 11, 2009 at 11:47 PM
SICWITHHATE
  • 7 POSTS
i do have an autozone nearby...im getting a voltage tester today so let the fun begin...
Feb 12, 2009 at 3:55 AM
ZACKMAN
  • 4,202 POSTS
Let us know what you find out.......
Feb 12, 2009 at 8:54 PM
SICWITHHATE
  • 7 POSTS
i should be getting a voltage tester tomorrow....how do i go about testing the wires?
Feb 13, 2009 at 3:34 PM
ZACKMAN
  • 4,202 POSTS
Unplug your rear O2 sensor (after the cat). Also unplug the corresponding connector plug on the PCM. CAUTION: Only unplug one harness at any one time. We are not testing the O2 sensor or the PCM, rather the wiring harness itself. So do not hook up the probes to the O2 sensor or PCM sides. Both probes have to be attached to the wiring harness plug. Set your multimeter to resistance (ohm). Place one test lead to the connector end (at PCM) and the other at the O2 sensor. 1. PCM connector A5 (BLUE) and sensor side (black/white) wire. 2. PCM connector D13 (GREEN) and sensor side either green/black or red/yellow. 3. PCM connector D14 (RED) and sensor side white/red. All 3 tests should result in 0 ohm reading. If you have any other number, that wire is bad.
https://www.2carpros.com/forum/automotive_pictures/55316_97civicecm_2.jpg
Feb 13, 2009 at 11:01 PM
SICWITHHATE
  • 7 POSTS
Thank you very much...id be lost without this information
Feb 14, 2009 at 1:33 AM
SICWITHHATE
  • 7 POSTS
what i have is a GB Instruments GDT-11 so i can not test the ohm of the wires due to the fact that the wires on my tester are not long enough so i need an alternate way of testing the wire harness....which wires do i test and what should they read?
Feb 14, 2009 at 2:21 PM
ZACKMAN
  • 4,202 POSTS
https://www.2carpros.com/forum/automotive_pictures/55316_gbt11_1.jpg
https://www.2carpros.com/forum/automotive_pictures/55316_85654007_1.jpg
Attach extension wires such as Dorman 85654 to your test leads. Just make sure that they don't touch any metal of the car. "Zero" ohm means continuous wiring, "infinity" means bad or broken wiring.
Feb 16, 2009 at 9:07 PM
SICWITHHATE
  • 7 POSTS
finally gave up..sent it to the garage. Got a call back saying it may be the ecm.....so we'll see
Feb 18, 2009 at 3:38 PM
ZACKMAN
  • 4,202 POSTS
Sorry I couldn't be more of help. But just ask them to test the circuit before replacing the ECM.
Feb 19, 2009 at 10:46 PM
