1997 Honda Civic Front Turn Signal Lamp replacement?
1997 HONDA CIVIC
66,000 MILES • 4 CYL • FWD • AUTOMATIC
KEYSMANFL
How do I gain access to the turn signal lamp to change the bulb? I can get to the headlight, but the turn signal is behind the fender and I can find no easy access to this light.
Jun 10, 2008 at 7:09 AM
KHLOW2008
  • 41,814 POSTS
Hi keysmanfl,
I do not know if our models are similar and if they are, you need to remove the lamp assy to gain access to the bulbs.
Jun 10, 2008 at 12:19 PM
KEYSMANFL
[quote:ca5b186067="KHLow2008"]Hi keysmanfl,
I do not know if our models are similar and if they are, you need to remove the lamp assy to gain access to the bulbs.[/quote:ca5b186067]
Can you tell me how to remove the lamp assy? I removed the two top screws and cannot see more, but it won't budge.
Jun 10, 2008 at 9:06 PM
KHLOW2008
  • 41,814 POSTS
Hi keysmanfl,
There are two pins at the rear of the lamp assy and you need to pry them free. Might take some force, pull the lamp assy straight out to the front.
Jun 11, 2008 at 6:23 AM
KEYSMANFL
Thanks for your help. I will give that a try.
Jun 13, 2008 at 6:47 AM
