1997 Honda Civic Excessive oil use and blue smoke at startu
1997 HONDA CIVIC
136,000 MILES • 4 CYL • FWD • MANUAL
TIGERTIM
Used car did not have any maintenance history. Added an oil "cleaner" just before changing the oil & filter along with a fuel system cleaner. 5w-30 convential oil & a honda oil filter was used. Replaced oil pan and seal and air filter. I Started the car the next morning and lots of Blue smoke came out of exhaust pipe. This happens everytime the car sits overnight & sometimes at freeway speed going up a steep hill there may be a little blue smoke. Once the car gets to operation temp the smoke goes away. Had a compression test done when the car was warm & it was 100 for each cylender. On a 200 mile road trip it consumed 1qt of oil. There are no visible leaks, the car got 35mpg with a mix of highway/city driving. It has plenty of power. Checked the spark plugs & they looked burned to a crisp. Hardly any node left. I can't believe the car even runs and runs well with these spark plugs. Again I have no idea how much maintenance has been done to the car if any esspecially after looking at the spark plugs. With that a timing belt may also need to be changed. Do you think that I have bad rings or valve seals, crankshaft seals, all the above or none of the above? Would replacing the spark plugs & wires along with rotor & cap and pvc valve and fuel filter help or should I stick with the rings and seals and timing belt first?
Aug 23, 2008 at 2:48 AM
KHLOW2008
  • 41,814 POSTS
Hi tigertim,
The bluish smoke during start up points to bad valve seals. Low compression of 100 psi means the rings are due for replacement.
Based on your description, I would recommend a ring and valve job.
Aug 23, 2008 at 9:51 AM
