1996 Honda Civic Powered Window Fell Off Guide
1996 HONDA CIVIC
MVPAGS
1996 Honda Civic
So I have a 1996 honda civic ex. The driver seat window has fell off the guide. The window will go down just fine. It will go up until it hits the rubber track about 3/4 up. It looks like the window is supposed to go inside the rubber track, but it looks like it is going on the outside. How do I get the window back on it's correct track?
Aug 2, 2010 at 6:32 PM
HONDA TECH 1818
  • 536 POSTS
It could be the window regulator is broken/worn or the run channel is worn. You can remove the door panel to inspect what is causing it to fall off track.
Aug 3, 2010 at 1:49 AM
