1996 Honda Civic 4 cyl
I have a 96 honda civic ex 1.6, 5spd. I just bought the car and I have had to put in about 12-24 ounces of water in the radiator after about 40 miles of driving and I dont see any leaks, also there was some kinda flaky stuff in the radiator water? I put in redline water cooler cause there was not much coolent. When I 1st start the car it idles about 1100 and it drives fine, I noticed this cream stuff on the drive way and it was comming from the airfilter, (witch is not stock it has a injen air intake system) and it went up and in the throttle body, After further inspection I noticed this cream stuff under the oil cap a lilttle on the oil dip stick and stuck on the walls of the valve cover and on and around the spark plug. I dont see any in the radiator the water is clear. Can this be a blown or pertial blown head gasket? Thank You for your time and help
Apr 12, 2008 at 4:45 PM
