So the other day I noticed a loss of pressure in my brakes. I thought I would just need to bleed them and when I started on the front left brakes I noticed my pads were shot, so I replaced the brake pads...while doing so I also noticed I would need a new caliper for the front left so I replaced that as well. Figuring that this would fix it, I started to try and bleed it (with the help of my brother pumping the brakes). I noticed that the front left brake was not putting out enough pressure to squirt out the brake fluid all nice as it should. I checked the bleeds on both the back two drums and the front right. They all bled fine with ample pressure to squirt it out. Thinking there might be a clog in the brake hose or the brake line I took them all off and there were no clogs at all. I don't know what it's called I refer it to as the "spider web" that is connected to all brake lines and the brake master cylinder and it feels like the line I had taken off had some pressure but not enough to push the brake fluid through. I re-installed the brake line and hose. checked the calipers and everything to make sure there's no gunk. Anyone have any idea what might be wrong? Still doesnt bleed properly.
Jul 20, 2009 at 4:18 AM
