1995 Honda Civic wont shift gears
1995 HONDA CIVIC
230,000 MILES • 4 CYL • 2WD • MANUAL
JLEVAUR1
wont shift in to reverse - grinds, cant shift from 1st to second. Oil light comes on and have to turn off engine to get into gear. clutch pedal goes right to floor but gears wont shift
Nov 12, 2009 at 9:08 AM
F4I_GUY
  • 3,302 POSTS
First thing is first.
If the oil light is on, shut the vehicle off and check the oil level.
The clutch issue is either a busted clutch, or the master or slave cylinder is leaking.
Nov 12, 2009 at 9:48 PM
JLEVAUR1
How do I determine which is bad on my car, master or slave clutch cylinder? Do you have a link to a page that tells or shows how to change either or both part? In your answer you stated that the clutch could be "busted" what do you mean by that and is this too involved to do myself. sincerely
Nov 13, 2009 at 6:11 AM
