1995 Honda Civic SRS Airbag
1995 HONDA CIVIC
210,000 MILES • 4 CYL • FWD • MANUAL
KHAMXIONG
  • 7 POSTS
I don't know f this is under electrical or not, but my SRS light is constantly on on my dash. It's never done that before. I checked all the fuses and they are in good working condition. Checked under the driver seat, works fine. all fuse boxes were checked, no burnt fuses. Tried resetting ECU, but still on. Need Help.
Jun 17, 2008 at 2:54 PM
KHLOW2008
  • 41,814 POSTS
Hi khamxiong,
Did you do anything twith the steering?
Get a scan done to find out which component of the SRS is malfunctioning. High possibility it is the driver seat belt receptor.
Jun 17, 2008 at 3:31 PM
KHAMXIONG
  • 7 POSTS
i did a power check with the seat belt receptor and there is no power going to it. how do i fix it without having do electrical re-wiring?
Jun 17, 2008 at 3:41 PM
KHLOW2008
  • 41,814 POSTS
Hi khamxiong,
When the SRS indicator light shows, the control unit cuts off, so you might not get anything.
You MUST scan and find out what is wrong before proceeding further.
Jun 17, 2008 at 4:48 PM
KHAMXIONG
  • 7 POSTS
[quote:60c153ac6d="KHLow2008"]Hi khamxiong,
You MUST scan and find out what is wrong before proceeding further.[/quote:60c153ac6d]
thanks, i'll try that out, it's so hard to find an obd1 code reader though. but i'll try it out. thanks again.
Jun 17, 2008 at 6:16 PM
KHLOW2008
  • 41,814 POSTS
Hi khamxiong,
There is a Service Check Connector at the main fuse box for SRS, yellow in color and plug into an empty slot.
Looping it would show some blinking codes, but not easy to decipher.
It can be used for resetting though.
Jun 18, 2008 at 6:59 AM
KHAMXIONG
  • 7 POSTS
ok i located the yellow connector in the main fuse box, i looped it using a wire, casue i don't have an obd1 code reader. it stayed on for about 5 seconds when i turned on my car, then it went away, then it came back on after about 10 seconds. don't know what this means, but any help would be super greatly appreciated. oh and before i did this, my seat belt light didn't work, until i tried this method, that's when it worked again. Any Help Please.
Jun 18, 2008 at 1:05 PM
KHLOW2008
  • 41,814 POSTS
Hi khamxiong,
Do the resetting first and see if it solves your problem.
1. Loop service connector.
2. Turn ignition switch on.
3. SRS light should go off in 6 seconds.
4. Within 4 seconds, remove loop and plug in again.
5. SRS should blink 2 times to confirm reset is ok.
6. Turn Ignition switch off.
7. Wait 10 seconds before starting.
Note. If after step 4 and the light remains on, repeat process again. If it does not work, you need a scan to find out the cause.
Jun 19, 2008 at 7:47 AM
