1995 Honda Civic Replacement of gas tank
1995 HONDA CIVIC
67,000 MILES • 4 CYL • 2WD • MANUAL
GXR SUZUKI
  • 4 POSTS
I just replaced the gas tank on my honda civic and also replaced the fuel filter. However, the car will not start. There is a spark but it appears not to be getting the gas. I went back through and made sure all the hoses were properly connected but no luck. Help, any suggestions?? It was running fine prior to this but since the gas tank was leaking I had to replace it.
Kris
Nov 3, 2009 at 3:19 PM
BLUELIGHTNIN6
  • 16,542 POSTS
fuel pump is probably not getting power. did you disconnect the battery when replacing the tank? check the fuses and the fuel pump relay.
Nov 3, 2009 at 3:22 PM
GXR SUZUKI
  • 4 POSTS
Wow, I'm impressed with the quick response. Can you tell me where the fuel relay pump is located on the 95 honda civic?
Nov 3, 2009 at 3:33 PM
BLUELIGHTNIN6
  • 16,542 POSTS
behind the left side of the dash, near the top of the kick panel. it might be labeled PGM-FI Main Relay .
Nov 3, 2009 at 3:45 PM
GXR SUZUKI
  • 4 POSTS
Sorry, but can you tell me where the kick panel is located? Us small time mechanics need all the help we can get. Thanks.
Nov 3, 2009 at 4:14 PM
BLUELIGHTNIN6
  • 16,542 POSTS
the kick panel is the plastic trim where your left leg will normally be near while sitting in the driver seat
Nov 3, 2009 at 4:18 PM
GXR SUZUKI
  • 4 POSTS
I've looked all over where you said and there isn't any plastic trim and I do not see a panel as it is wide open. Any other suggestions? Thanks for all your help so far.
Nov 3, 2009 at 5:19 PM
BLUELIGHTNIN6
  • 16,542 POSTS
see if this helps...
https://www.2carpros.com/forum/automotive_pictures/261618_Graphic_210.jpg
Nov 3, 2009 at 5:22 PM
