1995 Honda Civic Engine revving up and down.
1995 HONDA CIVIC
125,000 MILES • 4 CYL • 2WD • MANUAL
RJMOEN
My engine revs up and down. Its much higher than normal idle and kinda sounds like: vrooom, bah, vrooom, bah. The "bah" being the letoff sound; the cycle is repeatitive. The "bah" doesnt sputter or anything just a touch lower than regular idle. It doesnt do it all the time, isnt hot or cold specific sometimes does it after running all day, sometimes shortly after startup. Sometimes it continues for a bit sometimes it stops revving shortly after starting. You can only hear it when clutch is depressed or in neutral. It continues under load you just can hear the letoff. It does make my car seem a little jumpy as the engine is slightly revving continuously.
Feb 11, 2010 at 3:12 PM
2CARPRO JACK
  • 11,533 POSTS
I have seen the idle air bleed screws back off on those and creat a surging engine like you describe.Check and see if there is a straight blade screw looking adjustment on the throttle body, either on top or on the front where the air intake hooks up.If so turn it in 1/4 turn at a time until it quits doing that
Feb 11, 2010 at 3:46 PM
