1995 Honda Civic BRAKES
1995 HONDA CIVIC
110,000 MILES • 4 CYL • FWD • AUTOMATIC
BILL1971
i HAVE A 1995 HONDA EX AND MY FRONT RIGHT AND BACK LEFT BRAKE DOESN'T WORK but the other two brake do .The two that don't work when I took brake line of no brake fluid comes out of line I have checked al lines and no leaks .Help.
Oct 31, 2009 at 3:53 PM
KHLOW2008
  • 41,814 POSTS
Hi bill1971,
Honda brakes lines uses a diagonal system and the symptoms indicates a possible fault with the master cylinder.
Is the brake pedal low?
Try bleeding at the master cylinder to check if both the outcoming lines have equivalent pressure.
Nov 1, 2009 at 8:45 AM
BILL1971
Brake pedal is low I will try that tonight.Thanks Bill
Nov 1, 2009 at 3:45 PM
KHLOW2008
  • 41,814 POSTS
You are welcomed.
If you require further info, just reply to post and I would get back to you.
Have a nice day.
Nov 2, 2009 at 6:25 AM
BILL1971
Well that seemed to work but i did bleed everything and there is no air in lines but my padel is low the brakes work well but I have a ot of play before brakes engauge
is there a adjustment on he brake somewhere.Thanks For yourn help.
Nov 2, 2009 at 10:52 PM
KHLOW2008
  • 41,814 POSTS
Did you adjust the handbrake cable?
There must be some frre play for the rear calipers to fully self adjust
Loosen the cable and pump the brake a few times to readjust the rear brakes before readjudting the brake lever height.
Nov 3, 2009 at 11:15 AM
