1994 Honda Civic no pulse to fuel injector
1994 HONDA CIVIC
145,000 MILES • 4 CYL • FWD • MANUAL
JJMARTINSKY
  • 4 POSTS
what could cause my car to not get a pulse to my fuel injectors. ive already replaced the ignition module and checked the ecu.
Feb 24, 2010 at 2:53 PM
KHLOW2008
  • 41,814 POSTS
Hi jjmartinsky,
If sparks are available,then the most likely cause is a bad distributor. If any repairs on the engine was carried out, check the ground at the thermostat housing.
Feb 25, 2010 at 10:44 AM
CUSTOMIZER 29
  • 8 POSTS
[quote:ef3d04ab87="jjmartinsky"]Electrical problem
1994 Honda Civic 4 cyl Front Wheel Drive Manual 145000 miles
what could cause my car to not get a pulse to my fuel injectors. ive already replaced the ignition module and checked the ecu.[/quote:ef3d04ab87] bad cam or crank sensor can cause no pulse to injectors.
Feb 25, 2010 at 2:25 PM
CUSTOMIZER 29
  • 8 POSTS
[quote:4fa3f992dd="customizer 29"][quote:4fa3f992dd="jjmartinsky"]Electrical problem
what could cause my car to not get a pulse to my fuel injectors. ive already replaced the ignition module and checked the ecu.[/quote:4fa3f992dd] bad cam or crank sensor can cause no pulse to injectors.[/quote:4fa3f992dd]do you have spark?
Feb 25, 2010 at 2:26 PM
JJMARTINSKY
  • 4 POSTS
no there is no pulse
Feb 25, 2010 at 2:29 PM
JJMARTINSKY
  • 4 POSTS
and no there is no spark
Feb 25, 2010 at 2:31 PM
ROBDOBB
  • 0 POST
My 93 did the same thing... they put a new distributor in it and she fired right up, runs like a top.Ran me about 275.00
Oct 5, 2018 at 5:04 PM
