1994 Honda Civic Engine swap; V-Tech not working
1994 HONDA CIVIC
CWOOD
Engine Mechanical problem
1994 Honda Civic 4 cyl Front Wheel Drive Manual
B16 engine swap was done @ last year. V-Tech has not worked properly since. I have taken it apart and cleaned it, but no result. What else can I check? If it is not wired properly, how is the best way to check this?
Mar 27, 2009 at 11:40 PM
F4I_GUY
  • 3,302 POSTS
With the key on, the vtec soleniod should have power (it only has one green wire going to it)
Also the v-tec pressure switch (the oil switch) has two wires on it. One wire is ground the other wire is power. Ensure that this is all correct and I will get back to you.
Also, what ECU do you have? P30? P28?etc.
Mar 28, 2009 at 8:10 AM
