1993 Honda Civic Recent Overheating...Car Idles High &
1993 HONDA CIVIC
230,000 MILES • 4 CYL • FWD • AUTOMATIC
DRJIMMY
My 1993 Honda Civic DX recently overheated. After filling the radiator reservoir & letting the engine cool down, I drove the car home. The next day, with the engine cool, I was unable to get the radiator cap off, but the level in the reservoir was good, so I drove the car. When the car is in park, or neutral the engine constantly idles high, then low, high then low. This doesn't happen when the car is in drive. The temperature gauge stays in the normal range, for about 10 - 15 minutes of running and then it shoots all the way to Hot. This is despite the fact that both the coolant and oil levels are normal. What could be causing this?
Oct 26, 2010 at 1:35 AM
Hi drjimmy, Welcome to 2carpros and TY for the donation
Shoots to hot position -replace the thermostat and then bleed the cooling system.
Fluctuating idle: clean out idle air control,EGR and PCV valves and test the throttle position and manifold absolute pressure sensors, look for vacuum leaks.
Oct 26, 2010 at 2:39 AM
DRJIMMY
Hi, thank you for your answer to my question. I'm taking my car in to the shop today...I hope I didn't crack the head gasket...Take care
Oct 26, 2010 at 11:58 AM
Are you physically overheating might not be the headgasket
Oct 26, 2010 at 12:47 PM
