1993 Honda Civic Front brakes Holding brake pressure on bra
1993 HONDA CIVIC
CG15
Brakes problem
1993 Honda Civic 4 cyl Two Wheel Drive Manual
Hello Im having problems with my front brakes. I was having a problem with the front brakes not releasing pressure after I applied them or just doing it on its own. So I replaced the front calipers, rotors and brake pads. I drove it for two days and starting having the same problem again. I then had the brake booster and the master cylinder replaced. I drove it home fine from the shop. I didnt drive it for a day and then took it to work Monday and it started up again and I drove 3 miles to work with brake applied without me touching it.
Sep 21, 2009 at 3:51 PM
F4I_GUY
  • 3,302 POSTS
How do you know the brakes are applied? Have you even looked at the rear to see if they are adjusted to tight?
Sep 21, 2009 at 6:09 PM
CG15
Because the calipers are smoking in the front.
Sep 22, 2009 at 8:47 PM
