1992 Honda Civic Fail safe relay
1992 HONDA CIVIC
219,000 MILES • 4 CYL • FWD • MANUAL
SUSUMU
Where is the fail safe relay located and what effect does it have on Abs system?
Oct 10, 2008 at 10:52 PM
KHLOW2008
  • 41,814 POSTS
Hi susumu, The failsafe relays are located in the ABS fuse box.
https://www.2carpros.com/forum/automotive_pictures/192750_FailSafe92CivicMitchell_1.jpg
Fail-Safe Function When an abnormality is detected in the main system, solenoid valve operation is turned off by fail -safe relay. Under these conditions, the ABS system operates as a conventional brake system. The fail-safe function comes on with ABS warning light.
Oct 17, 2008 at 11:35 AM
SUSUMU
thank you, this a big help and the picture is a plus
Oct 17, 2008 at 1:26 PM
