Hello, and first and foremost I'd like to thank you in advance for any help you can give me. I changed out my intake manifold for an aftermarket one today, and for whatever reason when I started my car, the engine would rev itself...it goes from about 1,000 to 1,500rpms, repeatedly and continues to do so unless you either shut the car off, or pull the connector to the sensor map assy. The new intake manifold does not have a place to put the EGR valve on, so I didnt know if this may have something to do with it? A buddy of mine said there may be a vacuum leak? I checked and put in new gaskets with liquid gasket as well between the throttle body and intake manifold, and the intake manifold and where it bolts on to the block. Any help would be greatly appreciated! Thanks again for your time!
Sincerely,
Ryan Sanderson
Sincerely,
Ryan Sanderson
Aug 29, 2009 at 8:03 PM
