Steering problem
1991 Honda Civic 4 cyl Front Wheel Drive Manual
After i swapped out my single cam for my b series i took it out for a drive and when i turned it felt like my tires where spining but at the same time something was somewat holding on making the left tire screech off the ground. i changed out my axle and the whole knuckle with a new rotor but still the same problem. Only happens when turning in gear and even if at a stop when taking the turn. The motor was in a realtives car same exact like mines a 91 honda civic hatchback and when he had it in his there was no problem. The only problem i see is a torn boot in the inner rod can that be the problem?? or should i just replace outer/inner tie rods to see wat happens???
Oct 22, 2010 at 7:40 PM
