1991 Honda Civic Lights flicker inside while driving
1991 HONDA CIVIC
88,000 MILES • 4 CYL • FWD • MANUAL
GIGANTO_LOG
I recently did an engine swap on my civic and since then my interior lights flicker while driving, however it is only when my headlights are turned on. When they are not on everything is fine. When they are on all the lights in my car flicker including the instrument cluster, the clock, and my cd player. When the engine was swapped I had switched the entire wiring harness over to the car but had to change out two of the plugs that went into the fuse panel (under the dash). I have no idea what the deal is!! Any advice would be greatly appreciated!
Oct 20, 2008 at 1:45 PM
KHLOW2008
  • 41,814 POSTS
Hi Giganto_log,
Check the groundng straps and alternator charging rate. Check the alternator wire connections as well, it could be loose.
Nov 4, 2008 at 11:01 AM
