1991 Honda Civic Fuel-System Suspected
1991 HONDA CIVIC
194,000 MILES • 4 CYL • FWD • AUTOMATIC
CRAIGENSTEIN
I received a '91 Honda Civic DX Hatchback. It has been sitting for several years, and does not run. Everything "looks" great...no grease/grime/leaks/dents/rust/etc...almost like "new", but the odometer reads 194,000...so NOT "new". The former owner's father told me that it "quit" on his daughter, and she took it to a mechanic. The mechanic stated he thought it was the timing belt (loose, broken, jumped, etc). Upon my inspection, the timing marks on the crankshaft pulley as well as the camshaft pulley, all line up perfectly with TDC (checked with a probe in #1 cyl and indeed it was @ TDC). Also, I checked the spark, and it was very strong (just checked with the #1 plug though). So, I think I can rule out "timing" (unless you experts tell me otherwise). Next step would be "fuel". I need some advice for how to troubleshoot the fuel system...fuel pump, pressure regulator, injectors, etc...
Thanks in advance...
Craig
Mar 26, 2010 at 4:21 PM
LEGITIMATE007
  • 5,121 POSTS
i have some info on checking fuel pressure, does it try to turn over?
Mar 26, 2010 at 7:27 PM
LEGITIMATE007
  • 5,121 POSTS
LEGITIMATE007
  • 5,121 POSTS
CRAIGENSTEIN
[quote:39e7ba645e="legitimate007"]i have some info on checking fuel pressure, does it try to turn over?[/quote:39e7ba645e]
Yes...between the time I made my post (when I stated it did not run) and your reply, I managed to get it running. It runs well at over 1500 RPMs, however it idles roughly. I suspect the "Idle Control Valve" (I understand that this part frequently goes bad on these older Hondas )? I also plan on replacing the fuel filter (as the vehicle sat for over 5 years outside). Any other suggestions for determining the rough idle problem ?
Thanks for ALL of your replies...you are VERY helpful !
Regards,
Craig
Mar 27, 2010 at 11:15 AM
LEGITIMATE007
  • 5,121 POSTS
the egr valve will cause this problem too
Mar 27, 2010 at 11:20 AM
