1991 Honda Civic engine sputters after engine is warmed
1991 HONDA CIVIC
206,500 MILES • 4 CYL • FWD • MANUAL
LONG HAUL
12/6/07 After driving about 15-20 minutes the engine begins sputtering. I replaced the spark plugs and fuel filter a couple weeks ago. Yesturday I replaced the spark plug wires. The problem doesn't really occur if you give it a lot of gas. Usually I have to push in the clutch and rev it up a bit. Then it sounds like it has been cleaned out. After just a couple seconds though it starts sputtering again.
Dec 6, 2007 at 7:44 AM
2CARPRO JACK
  • 11,533 POSTS
Is or has the check engine light been on? Need to get it hot and check the quality of the spark. Has the oxygen sensor ever been replaced? At that mileage it should have one installed as a maintenance item
Dec 6, 2007 at 10:42 AM
