1991 Honda Civic clutch shifter
1991 HONDA CIVIC
192,542 MILES • 4 CYL • FWD • MANUAL
SHORTE
My 91 honda clutch sticks when pressed and released is there something wrong with the peddle or does it just stick and need to be cleaned?
Mar 23, 2009 at 12:08 PM
F4I_GUY
  • 3,302 POSTS
Does the pedal stick to the floor when depressed? if so, ensure the clutch cable is properly adjusted, and if it is you may have a pressure plate issue which means the transmission may need to be removed.
Hope this helps.
Mar 23, 2009 at 5:50 PM
