My 91 honda clutch sticks when pressed and released is there something wrong with the peddle or does it just stick and need to be cleaned?
Mar 23, 2009 at 12:08 PM
F4I_GUY
CERTIFIED EXPERT
Does the pedal stick to the floor when depressed? if so, ensure the clutch cable is properly adjusted, and if it is you may have a pressure plate issue which means the transmission may need to be removed.
