1990 Honda Civic White smoke coming out of exaust
1990 HONDA CIVIC
175,000 MILES • 4 CYL • FWD • AUTOMATIC
QUICKSTER
  • 13 POSTS
Two nights ago I was driving home from work about 20 blocks away from my house and I noticed that the temp gauge was 3/4s of the way to the red, so I pulled over immediately and turned my car off. I let it sit for a few minutes and then turned the key to ON and saw that the temp gauge was back down to its normal position. So I started up the car to drive it back the 20 blocks and a bunch of white smoke billowed from my exaust. I'm assuming that this was coolant because it smelled sweet. I checked it the next morning since it was like 11 at night when this all happened. I topped off the water/coolant and started it up. just a little bit of white smoke i noticed as i was driving it around for like 10 minutes to make sure it wasn't going to overheat on me again. i got out of the car and checked all the hose and looked underneath the car in a dry area for leaks. I didn;t notice any so I went to work. No problems there and back. Today I was off work so I drove to my friends so we could do the timing. No major white smoke, just a little bit when I first take off from a complete stop. We undid the battery, unplugged the computer that adjusts the ignition timing and bridged the terminals. Turned on the car and saw the wire frying, so I turned it off immediatly. We adjusted the wire a bit and turned the car on. Everything being fine this time except for lots of white smoke again. I adjusted the timing until it was good and the engine idle screw until that was good. Car is running and idling better now. Not perfect but what can I expect from a 19 year old car. White smoke still coming out quite a bit. Checked my oil with the dipstick and smoke was coming out of the channel my dipstick goes into. doesnt seem good. so i drove it back home. on the way home the car overheated again. i caught it fast this time. pulled over, turned on my heater and saw the temp gauge go down to normal. so i drove it to autozone and bought a thermostat. it almost overheated 3 more times on the way home, but every time i turned on my heater full blast it would go back down. i got home and replaced the thermostat and gsasket, but over torqued one of the bolts on the housing and it snapped.(well not me, but my friend did). so now i gotta go to a pick-a-park and pull a housing unit and bolt for the cover that snapped. So I haven't figured out quite yet if the car overheating was my thermostat. so now to my questions. what is with the white smoke? where should i start? any quick fixes to limp it along if its a blown head gasket? does the problem with my car overheating sound like its a faulty thermostat?
Oct 20, 2009 at 11:18 PM
KHLOW2008
  • 41,814 POSTS
Hi quickster,
It is possible the head gasket is bad due to the overheating as the swet smelling white smoke indicates coolant is being pushed out of the exhaust.
Did you check the coolant level in radiator?
Did you check if the cooling fans are working?
If the smoke is slightly grey, it is oil being burnt due to valve seals or piston ring fault.
Oct 22, 2009 at 1:32 PM
QUICKSTER
  • 13 POSTS
Yea I checked the radiator fluid. The smaller fan on the left side of the car(driver side) is working, always on, but I've never seen the one on the right side come on ever. its just always been out since I've owned the car. Any places you would reccomend buying a head gasket kit?
Oct 22, 2009 at 2:47 PM
KHLOW2008
  • 41,814 POSTS
For automatic models, both fans should start working when the AC is operated or when the fan switch is activated when the coolant heats up to a set temperature.
If the problem of overheating had been there for some time, just a head gasket replacement would not be sufficient.
The cylinder head would have to be refaced and there is a possibility the cylinder block face needs to be worked on too.
Parts can be obtained at most parts outlets. If you are at it, I would recommend replacing the valve stem seals as well.
Oct 23, 2009 at 6:48 AM
