1990 Honda Civic Fan dose'nt work
1990 HONDA CIVIC
238,910 MILES • 4 CYL • 2WD • AUTOMATIC
MONDOV09
I over heated yesterday going toi the dentist several towns away and so i change the thermostat ! but opon doing so i notice two things 1. the temperature gauge is not working any longer and the electric fan is not turning on ! I check the fuses there all good but im not sure what happened maybe a wire broke that i cant see ?
Jan 7, 2010 at 6:59 AM
JDL
  • 16,098 POSTS
Welcome to the forum, are there any codes? Possibilities, faulty fan-- relay-- coolant temperature switch-- wiring circuits. To check for codes, the ecu should be under the carpet, passenger side footwell. When you turn the key on, no further, there is an led that will flash codes, if any, you count the flashes to get the codes. One flash is a code one, two flashes is a code 2 and so on.
You can also take connector loose from fan, use jumper wires from battery for voltage and ground, to circuits that go to the fan, use inline fuse on jumper. Black wire with yellow tracer is voltage. Blue wire with black tracer is ground. See if the fan will run?
Jan 7, 2010 at 10:09 AM
