1989 Honda Civic Fouled plugs after replacing distributor
1989 HONDA CIVIC
190,000 MILES • 4 CYL • FWD • MANUAL
EYEZALIVE
So I replaced a failing distributor (the car was running rough and frequently stalling) and, for a moment everything was running fine. A few miles later I noticed exhaust smoke which increases when I step on the accelerator. Checked the plugs and all 4 are dark and wet (apparently fouled). What has happened?
Jan 25, 2010 at 8:55 PM
KHLOW2008
  • 41,814 POSTS
Hi eyezalive,
Check the ignition coil. It could be weak resulting in weak sparks and incomplete combustion.
Was the ignition timing checked after installing the distributor?
Jan 29, 2010 at 12:44 PM
