Car listed above has an ivtech engine.Whenever I start my car first time in the morning after the car not being used for more than 10 to 12 hours, the engine shuts off whenever I press clutch initially for the first 2 to 3 KM’s. Once I drive more than 2 KM’s the car functions well and the engine also does not shut off then. This happens only for the first 2 to 3 KM’s when I start the car after a long interval.
Mechanic checked the car and changed the air filter, ignition coils, all spark plugs, also got the fuel injectors serviced and tested.
Got the car checked on ODB device which showed errors; manifold absolute pressure (MAP) sensor circuit high voltage (p0108) temporary. But this error went away after getting all the above things done, the car runs well but at the start as mentioned it shuts off for initial km’s.
I need some expert comments.
Mar 10, 2020 at 8:42 AM
