2008 Honda City faulty cylinder rings???
2008 HONDA CITY
35,000 MILES • V8 • 2WD • MANUAL
SHUBHA
when picking up speed on changing gears, after a few kms, the car suddenly jerks , almost comes to a stop and picks up again. has been happening for a while now. the service centre is not sure what could be the problem . say it could be due to faulty cylinder or is it piston rings. which may have to be changed and will cost a hell of a lot. is this a manufacturing defect or a problem develope d over time due to driving and road conditions. need advise please. from bangalore india
Mar 11, 2010 at 9:24 PM
The clutch could be slipping if not Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Mar 11, 2010 at 9:57 PM
