I have a 1998 Honda Accord 4-dr Sedan 4-cyl. Whenever I apply the brakes and come to a complete stop or leave the car running and in park or drive, I get a bad vibration in the steering wheel and dash. It use to do this very bad whenever the ac is turned on, but now it's with or without it on.
Another problem is that the check engine light came on about two months ago. Took car to auto zone to test with computer scanner. It showed that oxygen sensor in bank one is bad. Changed oxygen sensor and about one month later, check enging light is on again. Take car back to auto zone to test again and it shows oxygen sensor in bank one is bad. Well I changed it again and about 20 minutes down the road, guess what? check engine light is back on.
Change oxygen sensor in front of cat converter and cat converter back in 2004.
Could it be the oxygen sensor causing the vibration in steering wheel and dash board?? Honda dealer said that there were too many sensors to determine the cause of vibration. Isn't that why they have the computer scanner for? to solve the problem.
---Check engine light
---Bad vibration in steering wheel and dashboard
Can you help????
Can you help????
Jan 23, 2007 at 9:38 PM
