Turn light problem
HONDA ACCORD
SIRIP
I have '94 Honda Accord 4D. Recently, turn lights started behaving weird. I hear the tick..tick..tick..noise for a while without indicator and turn light flashing. After 4-5 secs, the lights start flashing also and everything is normal. This behavior is more apparent when I use the turn signal for the first time in the morning. As I use it more and more during the day, this behavior is less apparent i.e. lights start flashing sooner. Also, when I use turn light for the first time in the evening after parking under sun whole day, lights start flashing immediately.
I checked all lights for burned out ones. Everyone looks fine. So, I figured it's the flasher that's malfunctioning.
Couple of questions
1) Is my diagnosis correct ? If not, what else should I look for ?
2) How do I pull the flasher out ? I located it under dashboard, but wasn't able to simply plug it out. Is there anything holding it ?
thanks for your help
May 12, 2006 at 5:05 PM
BRUCE HUNT
  • 3,754 POSTS
I think the manual will assist with pulling the flasher, but your diagnosis should be correct. It is the flasher that is failing.
May 13, 2006 at 1:59 AM
