I have a 1988 Honda Accord, 2.0 liter engine, approx 85k on this engine. Aquired car with a seized engine - got a used engine from a local junkyard - replaced several parts while engine was out, i.e clutch, pressure plate, release bearing, timing belt, drive belts, hoses, necessary gaskets. I used the intake, carb, and exhaust manifold from the seized engine because they were in better shape and the used engine did not have a carb. My first problem was a cracked stator magnet in the distributor causing very weak spark. Got car started, noticed fuel coming out aroung needle valve on top of carb - o-rings bad - also noticed fuel in oil. Rebuilt carb - still getting raw fuel in oil pan. Have been over and over vacuum hose routing, etc. Can't seem to find the cause - Please help!
Feb 19, 2007 at 5:15 AM
