fuel pump fuse location?
HONDA ACCORD
BILLW
  • 4 POSTS
92 Honda Accord 4 cylinder no fuel pressure. Checked pressure regulator with clear vacuum line and looked ok, fuses inside are good, so I replaced the fuel pump. Car still doesen't run. Is there a relay or other check I can do ? no fuel pressure at the fuel rail and I cannot hear fuel pump kick on for 2 seconds when you turn the ignition like it is supposed to. Please help !!!
Oct 26, 2007 at 9:39 PM
MERLIN2021
  • 17,250 POSTS
either the IAC or the MAF
Aug 12, 2007 at 4:20 PM
You need to inspect and test your fuel injection main relay it powers the fuel pump thru the yellow wire at pin 4 at relay.
Oct 26, 2007 at 9:46 PM
BILLW
  • 4 POSTS
Can you give me an idea of where the relay is located and how it looks ? How many wires or some description to be sure I have the right one ? Thanks.
Oct 26, 2007 at 9:54 PM
Behind left side of dash see below
https://www.2carpros.com/forum/automotive_pictures/12900_relay_for_celica_94_1.jpg
Oct 27, 2007 at 4:31 AM
BILLW
  • 4 POSTS
Thank you ! The information was fast and helpful ! The diagram you showed me for a 94 accord makes it look like the relay is to the right of the steering wheel, and on a 92 model it's on the left kick panel above the fuse box. Once I found it and tested it, it was bad and replacing it did the trick ! Thank's again, B.W.
Oct 27, 2007 at 3:29 PM
You're most welcome and please! tell friends about us we're here to help people in need.
Once again TYVM for your donation and have a happy holidays from 2carpros.com
Oct 27, 2007 at 5:04 PM
