HELP
HONDA ACCORD
TOONZ
Hello I own an 1987 honda accord lx i had the head replaces after it blew out i have had a few shops touch this car and everything from the head up is new gaskets included the car starts but is loud and does shake a lil when the car starts it smokes for like 1 min disapears but there is a strong odor from the tail pipe when i say loud it sounds like the lifters or something i was told by one shop i have no oil pressure but since i have had the car home the lights have remained off unless i drive the car for 3 to 7 min im at a loss i have drained my savings into the car its an awsome car but i need help PLEASE HELP
Jun 6, 2006 at 1:39 AM
MACAT
  • 17 POSTS
wow, have the valves been adjusted? if not they may need to be. was there any damage to the head when it blew? (warpage, valve damage)
unadjusted valves can sound realy bad almost like a rode knock, check it out.
Jun 6, 2006 at 9:52 PM
TOONZ
ok the original head was cracked i was told and the rods had melted so everything is new. I will have the cars valves adjusted Thank you soooo Much for that advice. Can the valves affect the way the oil pressure is ? Which At the moment i was told i have NONE. if the valves are not adjusted does this affect the timing and would this also affect smoke be it very little for me not to pass emissions ? thank you again for all your help and knowlege.
Jun 7, 2006 at 8:25 AM
