fuel pump
HONDA ACCORD
IPTORRES
I have a 1993 Honda accord se 4 cylinder(standard size) I don't know the engine ccs but it is an SE.
My problem is the car starts most of the time but at times the fuel pump does not pump. when it does run, you can hear it when the switch is in the on position, but when it doesn't, I check and you can not hear it pumping when switch is in the on posion. It will run for a few days, no problem, then all of a sudden it will not start if you stop it then try and restart it after a few minutes or few hours. the problem is intermitten. When I checked the error code It looked like it was error code zero, an ECU problem. I haven't been able to work on it lately but I plan to erase the history and see what comes up next time it does it again.
Aug 2, 2007 at 9:09 PM
BRUCE HUNT
  • 3,754 POSTS
Sounds like it might be the EFI relay located in the car and up under the dash on the driver side.
Aug 6, 2007 at 11:00 AM
