Greetings. My daughter's 1990 Accord 2.2 Ex died while driving. I got 12V to distributor but nothing at the plug. I replaced the distributor with a new not rebuild from Oreilly Auto Parts. Car ran fine for a day then check engine code 4 (crank angle) and no power under load occurred. I took it to a certified mechanic who said the distributor was bad. OReilly replaced and I reinstalled the new one. I cleared the code 4. The car ran great for a day. Then the exact same thing is now happening. I have heard everything from a bad distributor (again) to a bad ECU. The car runs but lacks power, and crank angle code. I was told I could have the ECU tested to verify. I am open to any suggestions. I do not want to put to much into a car that is not worth much except to my daughter. Thank you.
Mar 20, 2007 at 12:22 PM
