The right turn signal on my 2003 V6 Honda Accord with 103,000 miles stopped working. The left turn signal is working. When you push the turn lever up it seems like you are signaling and goes into place and then goes back to the center after the right turn, but the right signal does not light up on the front or back of the car.
It does not appear to be a problem with the light, because the right signal light does come on when activated with our keyless entry device, however The right signal does NOT light up when the hazard lights are turned on. Is this problem caused by the turn signal switch or is it an issue with the flasher? Thanks for your help!
Crista
Crista
Aug 4, 2007 at 11:13 AM
