Brake Problems - Brake Pedal goes to the floor
HONDA ACCORD
95ACCORDLX
Hello, I have a 1995 Honda Accord LX V6 with 189,000 miles on it. Over the last few years I have been having problems with the brakes on this car. When I press the brakes and begin slowing down, the car will come to a complete stop and then the brakes will start depressing to the floor? The car begins to roll forward and I have to press even harder on the brakes to get the car to stop. Most mechanics have told me that they can't find a problem with these brakes.....with the exception of one mechanic who was able to fix the problem. This mechanic told me there was an extra brake reservoir on this car and that it was empty and causing these brake problems. The problem now is that the brakes are doing the same thing again and I can't find this extra brake reservoir to fill it up! To make matters even worse......the mechanic that was able to fix this problem has retired and closed his shop and I have no way of getting in touch with him. Can you tell me where this extra brake reservoir is located and how I might can access it to fill it up? Or if there may be any other issue here that I'm not aware of? Thank you for your help with this issue.
May 8, 2007 at 9:40 AM
MIKE H R
  • 3,094 POSTS
I could be wrong but I think there is only one main resevoir on the car, inside it has two small reseroirs one for the front and one for the back brakes
May 8, 2007 at 6:36 PM
